Let top Italian sailmaker and racer Paolo Semeraro loose with a boldly innovative designer like Shaun Carkeek, give them a wide-open brief to just ‘do it better’ when it comes to contemporary cruiser-racer design and no surprise that the end result really is kinda special…
The quest for both performance and comfort on the same boat has been an ongoing challenge for builders and designers everywhere since there are inevitable compromises in finding appropriate solutions to achieve both. Yet the new Neo 570 c may be as close as possible to have found an optimally perfect solution, as confirmed by initial sailing on hull number one, Carbonita.
Two years ago the vision from project manager and builder Paolo Semeraro sounded simple enough: use the best possible elements of modern design and technology to build a boat that can be as fast as a TP52 in most wind conditions yet still be capable of being adapted for comfortable family cruising, and with both modes having reduced crew. Along with designer, Shaun Carkeek, it was determined that achieving this would be possible only in a longer larger boat, so the design settled on 57ft being a perfect length to accommodate all the elements of the design brief.
