cross over
We thought y’all might enjoy this look at sail crossover…
Sail crossover is a term used to refer to a boat’s combination of sails for all conditions. Each sail has a range of use, beyond which a smaller sail will replace it.
The points where the first sail needs to be replaced for the second indicate sail changes. The crossover diagram shows us the overlap points between the sails and the appropriate moments for sail changes.
At the crossover point of the sails, we will have situations where two alternative sail combinations are valid. Changes must be made if we expect conditions to vary in favor of one combination or the other. Read on.
