The MC52 might be the smallest catamaran in the McConaghy Multihull range, but this cat is no kitten.
The MC52 not only benefits from McConaghy’s vast experience building performance boats but also from a carefully considered use of carbon, that sees her precise hull forms achieve an optimum strength to weight ratio. With performance efficiency and reduced emissions, this is a fantastic coastal cruiser for all the family.
The MC52 has dual helm positions on the flybridge, allowing for the greatest sight lines forward as well as an elevated position that aids more difficult in-port manoeuvres – making her an ideal choice for those new to multihull cruising.
There are two accommodation layouts to choose from, with a three of four cabin arrangement, and an array of interior schemes available as well as the option to go fully custom.
McConaghy’s production series of multihulls, which ranges in size from 52 to 115 feet, is going from strength to strength. Several larger boats have already been delivered and the first MC52 is now under construction.
