wind it up
Why reduced line loads, improved flexibility and the reduced coiling diameter of the latest VO65 headsail furling cables should make for happier round-the-world sailors when the next Volvo starts in October
torqueTorqueLite 2.0
You’re on the foredeck of a Volvo 65, at night, bouncing up and down and heeled over with constant spray turning your headlamp beam into a light show, with the occasional half ton of green water trying to tear you off the boat while you wrestle with trying to furl the code zero. The watch captain says you’ll gain a full knot in boatspeed and hold course better by getting this sail furled and off the deck… quickly. The pressure is on.
In these trying circumstances aren’t you glad the sail luff is secured to a TorqueLite 2.0 cable? Even with the countless hours of performing this manoeuvre over many months, you know the process will be smooth and reliable due in part to the improvements Future Fibres have made in their latest cable product:
TorqueLite 2.0 has twice the torsional stiffness of its predecessor, halving the number of turns required to get your furl started. This means that less physical effort is expended, especially in demanding conditions, in getting the sail away quickly and safely, allowing the trimming team to re-mode more quickly. Read on.
