With warm weather upon us it’s time to mop the deck and get those boats back in the water! For years, boaters have used long, green and heavy hoses that provide inconvenient rips and leaks. Now, there’s the new, space saving Pocket Hose Top Brass II, a collapsible, light-weight hose.
Pocket Hose II is made from revolutionary DURA-RIB tubing which prevents bursting under pressure, while the new and improved outer lining can endure extreme weather.
Equipped with a heavy duty brass tip to withstand aggressive use and erosion, Pocket Hose also features tight seal technology which guarantees no more leaks or tangles and new brass connectors that are built like fire hoseconnectors and are three times more durable than the original fittings. In addition, a new “Solar Stripe Shield” that protects the hose from damaging UV rays and extends its life outdoors has been added.
Pocket Hose Top Brass II is available in 50 and 75 feet, starting at $29.99 at major retailers nationwide as well as www.PocketHoseTopBrass.com. (these things are really the best hose we’ve used. that’s bow god Rodrigo Doll loving it. -ed.)
Leave a reply
