the easy button
predict wind 7 17 ad
Big Pimpn’
Work out the best route to sail with a click of a button
With PredictWind’s weather routing tool, working out the fastest or most comfortable passage has never been easier. What can take hours to do manually happens with a click of a button on PredictWind.
Place a start and finish waypoint on the map, and select the start time for your passage. Then, using the selected forecast model, the tool will work out the fastest or most comfortable path to your destination. Any passage spans across changing weather patterns, swell conditions and currents, and the tool quickly calculates the optimal route for you. Test it out today, free of charge, with PredictWind.com.
 greenbutton
