Something pretty damn hot looking from our brand new advertisers…
The building of C&C Yachts new 30 One Design has begun. This 30 foot race boat, designed by highly acclaimed Designer Mark Mills, will be leading the way in 2014. Construction for the deck plug began in early November 2013 and now the shop is progressing along and building the hull plug. You can follow the 30 OD’s progress online here:C&C 30 OD.
The new C&C 30 is pure race boat, complete with a fixed composite sprit to accommodate an asymmetric spinnaker, carbon fiber rig, square top mainsail, Dyneema lifelines, fabricated steel fin keel with lead bulb, top of the line hardware package, and of course, water-tight hatches. Should the wind die down, the C&C 30 has a smooth running 2-cylinder inboard diesel engine to get you to and from distant race courses. This one design is race ready for around the buoys, but is also equipped for the shorter distance offshore races with a self-contained head and two settee berths. C&C Yachts will launch the 30 One Design in the Spring of 2014. www.c-cyachts.com.
