simon says
Simon Maguire is a perfectionist. Every Exocet Moth he and his team of eight build in their UK facility is the result of almost obsessive attention to detail. From the moment the hydrofoils start life as strips of ultra-high modulus (UHM) carbon fibre to the time the 10kg hull section is released from its mould tool, every aspect of these high-speed racing dinghies is honed to minimise weight and maximise performance. As we toured the modern building in Hampshire and saw four new hulls under construction, we asked Simon why his boats have become so sought after that they cost more to buy second-hand than to build new.
Despite a waiting list of owners impatient to get hold of a brand new £29,000 Maguire Exocet there are no plans to boost production, and the logic is reinforced by the results.
Maintain the standards
Each Exocet Moth is built to a design by Kevin Ellway and made by using PRO-SET LAM 125 epoxy resin and LAM 226 hardener to laminate a very thin lay-up of carbon fibre. PRO-SET epoxy has been formulated to completely saturate advanced fabrics with a minimal amount of epoxy to create mouldings that are exceptionally light and strong.
The hydrofoils, for example, are created in aluminium moulds, preferred as they are longlasting and free from warping. The finished mouldings are then post-cured at 75°C for seven hours in a modern, computer-controlled oven. ‘You can feel the difference this makes to the quality of the finish,’ Simon explains. ‘You get a really strong product and it needs to be, with the forces it will be handling.’
Read on.
August 27th, 2018
