gunboat-banner-ad-png
fish side 5 17
ullman banner ad
feel the rush
The 40 foot cat Rushour went over at the Royal Queensland on Wednesday, and the driver quickly posted a report to the SA Forums for the benefit of other cat owners.  Kudos to ‘bushsailor’ for a near-perfect after-action report full of lessons.
Forecast was for 20kn se wind.  We set the boat up with one reef and self tacking heady.  THIS CONFIGURATION IS VERY MANAGEABLE IN 20KN.
We started sailing to windward with the intention of building speed then bearing away to go downwind.  Main traveller was fully down and a crew member was holding the main sheet.
Speed built very quickly as we got hit by a big gust (40 kn). Hull started to come up, main was completely dumped but hull kept climbing.  I (helm) turned up to feather the sails but response was slow because all drive was coming from the heady and the bows were pressed.
Boat capsized sideways.  Whole thing took maybe 5 seconds.
  • Mistakes: Bloody B&G wind instruments were not working so no appreciation of building breeze. (Rushour commonly does 20kn on a shy reach so 30kn of wind across the boat seems normal.)
  • We never normally hold the jib sheet. (obviously a mistake)
  • We were rushed with some inexperienced crew and I  never allocated roles.
  • I was complacent. I never even come close to even flying the hull high on the new Rushour.
  • The gust of wind combined with boat speed gave approx 55 kn over the deck which was obviously enough to capsize a 7 ton boat.
  • The wing mast may have contributed to the capsize.
lucky we were only in 4m of water and Rushour has a very strong wingmast so we were able to attach ropes to the high hull and tow her around so the bows were pointing into the wind and towed her over.
The bottom hull was flooded and that helped to right the boat.  You need a very big tow boat to pull a big cat over. We used a commercial cat Cat of Nine Tails to pull her up.
We had her upright about 2 to 3 hours after capsize.  I would not want to go through that in the open ocean.  A huge thank you to all the people who rallied around and helped right, retrieve, clean the boat, and for all the messages.
It makes you realise how good it is to belong to a strong sailing community.
November 10th, 2017
